Hi,
I am new around here, but old when it comes to lightbars. I used to work on such as a sideline to working on radio systems with the volunteer fire, rescue and ambulance services from 1977 thru 1993. Everything from 6v single beacons to strobes.
But then a transfer from NY to NC for work pretty much put an end to that.
So, to cut to the chase, I began looking for something to put on my older (1997) Ford F350 truck which I use mostly for radio system work in the field. Sometimes I have to pull off to the side of the road to perform some measurements and felt I really need more than the stock 4-way flashers. So, I had the idea of putting an amber lightbar on top.
But, what? The entire industry changed since I last paid any real attention beginning in 1994.....
It wasn't hard to find this resource. There's a lot to read up on and I eventually went with what I know and am working on a Federal Signal Aerodynic model 25. I just can't get into the LEDs and I didn't like strobes back in the day. Plus, the 97 F350 is the style Ford began with in 1980, so a model 25 will fit right in.
So, I can't really comment on how much or little discussion is happening right now, but there has been quite a bit of content to read, that's for sure.
Stan
