Jet Solaris lighthead cut-off
bdwhit
112
Olathe,Kansas
I have a Solaris lightbar that is being mounted on a 'high cube' ambulance, and I need to disable the rear LED heads. I pulled up the install paperwork online, but was unable to turn the heads off. Manual states that the green wire is used for front or rear light cutoff, but when the bar is powered 'on', applying or removing 12v to the green doesn't shut off the heads. Any suggestions?
C17LVFD
Harrisburg, PA
Likely it’s not wired the way you’re needing to use the bar. My suggestion would be to open it up and remove the wiring to the rear heads from the flasher.
Best of luck,
Seth
bdwhit
112
Olathe,Kansas
Seth,
That was my idea as well. I noted that some of the other wires in the bundle do not work as "advertised". It;'s an old wrecker bar w/stop/tail/turn on the rear corners and 2 work lights facing the rear in the center section. I need to open the bar up to clean it and install new domes & a new power cable anyway. Thanks BW
Reactions: C17LVFD
