Mars Light
Currently I have a problem to run a JS1.
All functions (flasher, cut-off) works but the rotators do not go back to the starting position.
If I stop the power the rotators stand at the last position.
Is it correct that the white wheel turns counterclockwise?
Because so the lever (with roll- red B) on the micro switch is pushed away (red arrow) instead of towards the switch (green arrow).
