Wanted Led flasher boards or lightbar control
LenH
138
Texas
I am needing several led flashers. Will consider anything with 4 or more outputs but the more the better. Will consider using more than one board if I must. Needing to power up 16 heads because I have a Ecco bar that needs a flasher board and I want to retrofit something with better flash patterns into it.. I also have a mini project bar that I want to put 8 heads in.
Minnesota
I have a controller from a Whelen Patriot with all wiring. Will run 6 rear, 6 front, alleys and TDs. (I only ran 4 up front but it has 6 plugs so I presume it will run 6 up front) if you are interested.20190703_210423.jpg
Minnesota
It has a built in 6 head arrow plus a bunch of individual flash patterns. Might be able to find a video online. Open to offers, it has the wiring for all the led heads and control cable that most dont. I cant remember if I have the power wire or just a new connector. Purchased new power plug a while back, just dont know if I made a new harness or not.
LenH
138
Texas
Stilll interested in this for a spare shoot me a price
airflores
