Wanted LED Flasher controler
jdh
Geneva, FL
I am looking for a positive switching, 12 volt LED flasher that is capable of handling 20 amps. Must have the option to steady burn.
Thanks
JDH
Admin, I incorrectly listed this in the vintage section as well. Please remove as I did not intend to list this as vintage.
MtnMan
1,533
Eastern PA
Wow, 20 amps for an LED flasher? That would be something like 20-30 LED lightheads. I think you might be overestimating.
If you really need that much, you're probably going to have to run relays off the outputs of a standard flasher.
jdh
Geneva, FL
Yes. I have a bar that has 16 led heads. They each draw an amp. That is 16 amps. If I get something that supports 20 amps, then I have plenty of head room for inrush current.
C17LVFD
Harrisburg, PA
Might be worth picking up a liberty IO board or similar for the application.
Whelen SLFlash May also b an option.
"Theoretically" it would never flash both channels at the same time so it could get away with a 10 amp fuse..
ErikH
