LED replacement pods for FS Vector?
John Smith
Junior Member
304
74
CO, US
I've got a FS Vector, I think it's a "Smart Vector," and I was wanted to upgrade all of the lights to LEDs. I guess I'd like them to look similar to NYPD's Vector LED bars, as seen in this video:
I figure this won't be identical, as I assume NYPD gets these direct from Federal, but are there any aftermarket pods that are bright (Very), dependable, etc? Which do you all recommend?
Thanks!
Here is what NYPD has: http://www.fedsig.com/products/index.php?id=239
I would think you would be able to order replacement pods, but I am sure it would be more expensive then just buying the lightbar brand new. If you have are able to jog two of the heads on your Vector as take-down/alley lights, then it is a Smart Vector.
the nypd does use the vision SL , the only cars that ever had vectors on them were car's donated after 9/11 and they didnt have arrowsticks and were controlled by sw300 and had pa300's in them.....
and they did retrofit some of the SL's from red pods to red/blue-rear when the law changed
olmazey57
