blackcherryxj said:
Joe,
In short, yes. I do not see a problem with it. When you power up position 1, you'll provide constant power to the arrow. You will only be able to use the arrow with position 1 activated. You could also put it on a push putton output if you needed to activate at another time.
Paul
Yes I thought about putting it to a push button, but I decided against it since my bar is only on while on an off duty detail on a lane closure with magnets. Yes a 45" Legend does work with magnets.
acs680 said:
Um, no? Federal told you this?? The SS2000SM will not cause the LEDs to be dim when not in use on the Legend. I could maybe see this if you were using a true LED arrowstick that wired up with 12 volts to each head, however the Legend does not do this, as it goes through the serial interface module. The LEDs for the Signalmaster never see the power unless activated through the Serial Interface Module.
Really? You were listening to my conversation with Bill O'Connell - Tech Support Ex. 5352 at Federal Signal. Please look at my question once again. The
SS2000SM-SB will power LED Signal Masters dim when not in use due to the fact the SB series was designed for halogen Signal Masters and not LEDs. Bill clearly said the SS2000SM-SC or the SS2000SM-SD will in fact work with LEDs because those series of Signal Masters were designed for use with LEDs unlike the older versions.
leftcoastmark said:
I agree that it won't be a problem. To turn the directional arrow on, the SS has to close the circuit via the SM board on the siren.
I'd hook it up normally and try it that way. We have lots of Legends on SS2000's and haven't had any issue with what you're describing.
I am not to worried about this issue any more since I have an SS2000SM-SD on its way from a member on here, now to find two more speakers to run dual SS2000SM's... :yes: :yes: :yes:
Quentin said:
Just hook it up Normally. I never had an Issue when I had my Legend hook up to the SS2000SM
Wire just like page 59
http://www.fedsig.com/docs/2562365.pdf
Thanks I already have the manuals for both my Legend and SS2000. Just to be clear its the series of SS that matters according to Bill at FedSig. I know I have read this before but I just couldnt find it.
Thank you guys.
