Liberty lighthead staying on
mrburch24
139
Mobile, AL
I have a 2013 Whelen Liberty, all LED. With everything turned off I currently have a front lighthead, (center left) that is steady on, albeit dim. I've seen it do it a couple of times intermittently. If I turn on any function the lighthead will turn off and then back on a few seconds after I turn the function off. Obviously that head is getting a little power when it shouldn't be. Any idea what is causing the issue?
mrburch24
139
Mobile, AL
Just an update, yesterday I had another light head, rear, right center doing it too. I also noticed a lot of condensation inside the bar. I have removed and end cap to let it air out. I think that could certainly be the cause. I'll open up the bar over the holiday and see what it looks like. Thank you for the tips!
Reactions: Bvfa23
