Looking for an led light head.
Quentin
Senior Member
23
35
Lancaster, Nebraska
I have no idea if anyone has made one of these but I'm looking for two light heads to mount on to my tool box. I am wanting it to do park lights, brake/turn, and warning.
I thought Whelen M series could do this but I guess I was wrong. Any ideas
Sent from my PC36100 using Tapatalk
I guess you could wire them to do that but if you used warning lights for turning lights they would be too bright right? You could always just get two warning lights and spend $20 on some decent surface mount marker/turn signal leds..Just an idea.
KP
I'm open to any company that may have this.
And I'm not really looking to add many lights to it. Looking for an all in one.
Sent from my galaxy tab on TapaTalk
I have seen on National Grid electrical trucks that the tailights have a steady lower lightoutput but for turn signalling or for warning (4 ways on) there is a higher output, similar to the led turn/tail lights in newer cars...
the lights looked like this but im shure there are oval ones and etc..
http://tinyurl.com/4ow3lnp
Ok theres a couple of ways of doing this
method A:
[Broken External Image]:http://www.whelen.com/_AUTOMOTIVE/images/Lightheads/500/500_LED/hiresweb/50r00xrr.jpg
http://www.sirennet.com/wh52fblfrr.html
method b:
[Broken External Image]:http://www.able2products.com/Pictures/11_1005STT_Index.jpg
11.1005STT LED Flasher - Stop / Turn / Tail
• Solid-state
• Waterproof
• 10 flash patterns:
Tail Light - lights dim
Brake Light - lights brighten
Turn - corresponding light flashes
Strobe Flash - 7 selectable patterns similar to 11.1005SF
• 4” H x 2” W x ½” D
• Use only with LED lights.
I would use this able 2 flasher
Are you saying use the led you listed as A with the led flasher? I look at the wiring for the led and only see. Park, brake/turn, scan lock and ground unless I'm messing something
Sent from my EVO using Tapatalk
TNConstable
