Minitor v out of band programming
kinnelonfire75
Veteran Member
NJ & IA
Is there any way to do it? The two frequencies that i need are a distance apart from each other. I tried to get onto batlabs but i can't read their confirmation codes and i can't get in contact with their admins...the emails that i send get returned as Delivery Fails...
If you post the two frequencies here, a number of members could look and see whether or not the two are within the same split.
Those frequencies are in two different bandsplits, and there are two bandsplits between the two those frequencies are in. I do not believe there is any way to program a Minitor V for both of those frequencies, even using engineering mode.
As far as I know can't be done. I asked our radio man a while back with the advance programming if I could do our dispatch channel 154.XXXX and have channel two as a weather alert 162.xxxx and it couldnt be done.
The Apollo VP200 can be ordered with a wide split like that.As for the Vs,even editing/hacking them it cannot be done.
thewaywardswanderer
