WOFTECH PSE
That doesn't make sense. The power amp should be capable of maximum output regardless if siren tones, PA, or radio rebroadcast are being sent to it.You may find the siren volume is reduced if you try this application. PA functions usually top out at 45 watts and this may be the same with radio rebroadcast.
