Hello! Is it possible to find MS3000U siren wiring iagram or installation instruction? Thank you
Aries Member Nov 7, 2012 113 Ukraine Feb 25, 2020 #1 Hello! Is it possible to find MS3000U siren wiring iagram or installation instruction? Thank you
Jarred J. Lifetime VIP Donor May 21, 2010 11,583 Shelbyville, TN Feb 26, 2020 #4 i did a quick search yesterday when i asked all i could pull up was for the 4000 and 4000U its predecessor reason why i asked.. ok maybe a more seasoned member has an original or a pdf..
Aries Member Nov 7, 2012 113 Ukraine Feb 26, 2020 #5 Thank you! I found that it has the same 12 pin connector with the same wiring as P300.
S Safetyman Member Sep 18, 2017 52 Baldwinsville, NY Mar 8, 2020 #6 I believe I still have the MS3000 manual if that's what you need. I recall getting the manual from FS and it's pretty basic.
