Wanted MX7000 internal arrowstick harness
irishff
522
SW Missouri
I need an internal harness for an Mx7000 8 head arrowstick. 5+ feet of cable and must have the internal connectors. Lightheads and filters are not needed. Harness only. PM me directly please.
Elmira, ny
@shues there was only one arrowstick harness and its actually being used in an ledx2100 i built.
The rest of the harnesses were the kind to connect rotators etc. To.......and due to building numerous bars, i think i have one of those left :) (which ironically is going to be used in an upcoming build for a local firefighter)
Man that wiring came in handy lol
shues
NW Indiana
Do you know if you need the kind with seven wires for the newer ground side switched ArrowStik or the kind with nine wires for the older positive side switched ArrowStik? The easiest way to tell is to look at the outboard ArrowStik boards. If they take a four-pin connector, you need the seven-wire harness. If they take a three-pin connector, you need the nine-wire harness.
shues
NW Indiana
I have a whole bunch of the seven-wire cable, removed from a stand-alone ArrowStik. However, I do not have the internal harness for the MX7000 ArrowStik.
irishff
522
SW Missouri
I believe its a different connector but I could be wrong, can you send me a photo?
Caldwell205
