NFPA has 2 standards for emergency lighting on fire trucks; large vehicle and small vehicle.
Large apparatus = vehicles over 25' long OR if the lightbar is 8' off the road or more.
Small vehicle = < 25' long AND lightbar is < 8' off the road
If your vehicle is a 'small vehicle', then you only need an
NFPA compliant bar, front grille lights, and a light on each front corner facing sideways (there is no standard that the grille and corner lights have to meet, but best to use SAE Class 1). This also assumes you can see the bar from 360 degrees around the vehicle. For example, if you have an equipment box on the back that blocks the lightbar to the rear, then clearly you'd need to add lights to the rear as traffic approaching from the rear of the vehicle couldn't see the bar.
In the "small vehicle" class there is no requirement for any additional lighting, but keep in mind that
NFPA is a minimum standard.
The Hummer pictured above would be
NFPA compliant assuming the bar is < 8' off the road surface.
Pretty much any loaded bar will meet
NFPA, especially if it has a couple whites flashing in it facing forward. If you built up a bar, FedSig won't be able to certify it - they can only do that with bars that they have built and tested. However, given your description of the bar, I think it'd exceed
NFPA requirements.
See
Technical Guides for Compliance with NFPA and other standards | Federal Signal .
