No power at control head
Signalmaster
6
Long Beach California
Why everybody I just bought a ss2000sm but I cannot get the control head to light up the clicks when I turn the power on I hear a click when I click the microphone real quick but no lights on the control head I had two cables I ordered them new to go from the control head to the amplifier one's a reverse and one's a straight cable neither one of them lit up the control head. I get no lights no sound these are not factory cables from federal signal never from a second party on eBay which cable does one need from the control head to the amplifier a straight cable or a reverse cable. I use both of them and I cannot get the light to control head to light up at all any suggestions besides throwing it All away
kabsher8093
176
KY
Could be a few things.
- The backlighting and button sounds may have been turned off in the programming.
- The control head is bad.
- A standard "wall outlet to telephone" cable will work. It's nothing special about the cable.
- Try pushing the "Standby" button a few times until the backlighting comes on.
- As for the "beep" when pushing the buttons. It may be turned off in the programming.
Signalmaster
6
Okay so I'll use the straight phone cable and then I'm going to eBay and order another control head. thanks for your reply it was very quick. Don't see a way to program it it says power up but I can't power up..
Signalmaster
6
and now that you think about it I guess I should hook a siren up I've been clicking the microphone really quick just a quick click cuz I don't want to burn the amplifier out but I don't have a appropriate speaker yet so I should get a speaker and try it see if the makes siren or a PA function.
kabsher8093
176
KY
You will need both of these manuals.
When you test the siren. Be sure the position slider is on 3.
  • 255283.pdf
  • 255336.pdf
kabsher8093
176
KY
Do you have all of your wiring connected?
Your main power, power and ground from the plug on the back of the amplifier.
Signalmaster
6
Yes power ground and main power for their lights I got battery test battery none of the other wires are hooked up for a siren or for a horn the horn loop all that I haven't I haven't hooked up I'll check out those manuals thank you for posting those
Signalmaster
6
When I flip the power toggle switch I hear a click and I don't have a siren hook up so just real quickly I clicked the microphone and I hear it click in there so I just ordered a PA speaker from a brand new one from eBay so we can at least get a speaker in there to test
JPC
42
89074
Someone may have opened the control head and modified it to not have backlighting. I bought a ss2000sm once that the control head had an aftermarket relay installed in it so that position 1 on the slide switch was on all the time. You might want to open the control head and see if someone has been in it.
Reactions: kabsher8093
jaf10596
