North American Signal Strobe
348
1,017
Idaho
I picked up this blue strobe beacon at a surplus store today. It is made by North American Signal. It has a self contained strobe power supply and is a single flash pattern. It has a rubber base. The label on top of the dome shows how the light should be oriented when mounting it. I wondered why it would matter until I removed the dome and saw it has a horizontally mounted linear type strobe bulb. As I looked closely at the square plastic tray all the electronics were sealed into, I noticed the tray had a latch and hinges like the small plastic containers with clear lids. Obviously the lid was removed. The tray is mounted to a round metal plate with sits inside the rubber base with two bolts extending out the bottom for mounting. This was the first round strobe beacon I have seen with a linear type strobe bulb.
6CE38A34-2C8E-4577-A800-61081D4BFDEF.jpegD96E7952-6E22-4140-B8A6-3F916B630990.jpeg98D32A97-D2E7-4B0F-B79B-B9A9E8BE71CF.jpegA9FB1795-00A8-49E8-B32E-E4E29AC216B6.jpegBF39E647-6B0C-4536-8A69-63D578984198.jpegE47258FA-2B3A-4C1C-B306-3D57FA3BAE36.jpeg
ErikH
