opticom coding?
medic550
178
pa usa
Does anyone know how to change the opticom coded transmitter id's?
The tomar pack has a db-9 connector on it? Is there software that is needed to repogram the id?
Thanks
RedBlue
24
Washigton State
Of course the programming method varies among the different makes/models. The most current production Opticoms are programmed thru software. GTT (formerly 3M) sells a programming package with cable and disc for traffic engineers/installers. Some of the real old models were capable of being programmed through dip switches. I'm not familiar with the Tomar version, although if it has a DB9, it's safe to assume it's programmed through software as well.
Strobesnmore
382
Westerly, RI
You have high and low which you should be able to choose on the unit itself however if its a "coded" system its illegal for anyone but the person or company who owns that code to change, modify, use, etc.... When you buy a coded system from a company they have you hooked for life. They own the code so anything you buy you must buy from them. An "uncoded" system is better because apparatus from different communities can use their equipment in different cities or towns without issue. To better understand coding think of it as a PL tone used in programming radios. Its a sub frequency in addition to the main frequency used. Same applies to preemption only a person owns the PL and you can't use it without them selling it to you.
Hope this helps.
jaf10596
