theroofable
I installed a set of Whelen Par 28 lights with the white steady to replace fog lights on a 2013 Charger. When the driving mode (white) is activated, they start to flicker after about a second of being on. I am using the factory harness for driving mode/ground, then another trigger for the warning override. I saw there may be an issue with the canbus system due to an extra load, however these draw about 1A less than a stock fog bulb. Anyone have any experience with installing these on a charger and ran into a similar issue? I know I may just have to use a relay with the factory fog wire as the trigger but figured I'd ask here first.
