plastic wedge
TLE911 LLC.
58
Nebraska
looking for thick plastic that is easy to cut for forming wedges to mount lights. (ie. fill gaps, create angles to lower or rise light for proper function) I have a tap plastics have to look what it is again but is not easy to cut at all.
MtnMan
1,533
Eastern PA
Polyethylene (HDPE) is the translucent white stuff often used for kitchen cutting boards. It's easy to cut and shape using woodworking tools.
Downsides: pretty much impossible to glue, and the chips will stick all over you and your tools.
TLE911 LLC.
58
Nebraska
abs is what I was using. other than cutting on table saw with carbide blade I can't get it cut easily to the angles I need or anything. got any tips on how you do it?
OVERKILL
448
hamilton ontario canada
We lube blade with a Lennox wax stick and the blades we use are designed for plastic and non ferrous metals. Available at Home Depot. I believe they are made by Freud and they are Chrome to help prevent the plastic sticking.
wilsonbr90
1,427
Corning, New York
Delrin? Slightly more expensive but seems to hold up well in industrial settings. Available in black or white
jaf10596
