Problem with FS Dual Viper
Fighting17th
798
PA, Washington County
I have a Federal Signal Dual Viper S2 in all blue I've had laying around for a while. A month or two ago I decided to put a cig plug on it and install it in my truck. I TRIPLE checked the polarity on the cig plug to ensure that it was correct, then installed it properly with heat shrink butt connectors from Del City and shrink tubing and a heat gun, then made sure the fuse was 5 amp or less (can't remember for sure), then plugged it in, and nothing... So I checked the fuse and it was fine, so then I cut the cig plug back off and tested the light again with a 12v power supply, and nothing. The light was working fine with the power supply before I installed the cig plug.
I've installed many cig plugs and many lights and never experienced this before. Has anyone has any similar problems with Vipers? I've attached a few pics of the light. I got it second hand so I'm not sure how old it is as far as warranty. I took it apart and didn't see any loose wires, burn marks, etc.
May 10, 2012
156
New England
Is the lighter plug socket clean, properly aligned, and wired properly? Is that fuse intact?
Just for grins, reverse the polarity on the plug that you wired on. I've seen some Fords and Chevies with inexplicably-reversed wiring in the lighter plugs.
Fighting17th
798
That's not the problem. After I experienced some problems, I completely cut the cig plug back off and went back to using the alligator clips on the bare wires of black and red, and now there is nothing at all. even without the cig plug installed.
welcome to the crappy fed sig vipers.
check for an internal fuse. if there isn't, see if it can warrantied. if not its trash
Alboy29
351
United STates, New York
I dont even want to sound like a jack-ass, but is the pattern set to that stupid off pattern? maybe it is powering up and going right to that? Just throwing out suggestions if you exhausted all options
Fighting17th
798
I didn't see any internal fuses. I'll check again this weekend, then check on warranty info. If it can't be warrantied, I think I'm just selling it to someone who PMed me on here for parts. Thanks for the help.
Fighting17th
798
No, you don't at all. That's one of the first things I thought of. I tried tapping the pattern switch as well and holding it in for a different variety of times, all of which didn't work :( Thanks for the advice though.
bluestinger90
657
BC / California
Check the metal/plastic connectors where it meets the pc board. Those things are easy to break since Federal Signal doesn't design a strain relief mechanism into their power wires.
ErikH
