Proper Wire Routing Methods
alexjusti
4
Dalzell, IL
I'm looking to run wire from the firewall to my back seat on a 2020 Silverado. How does everyone generally run wire through the cab? I'm thinking of just running split loom under the carpet but I'm not sure if that's necessarily "correct".
Sparky_911
Supporting Donor
May 15, 2013
2,658
Central Illinois
If it's only a couple lines use the door floor plate sills as suggested above. They pop right off and have tracks in them for such things. You can get up to 3-4 runs of 16 gauge down each side.
dasher
155
USA/Pa.
I use to run them under the door strips
alexjusti
4
Dalzell, IL
I have a few things I can run under the door sills but I have a large bundle of approximately 10 wires that needs to run from front to back. I don't think they'll fit very well. Any ideas?
firebuff17
776
CT
I had a similar issue, a large bundle of wires from the front needed to get to the back wall of my crew cab. So I ran the bundle, protected with wire loom, from the front of the engine compartment, following one of the factory wire bundles, down through the engine compartment and down the frame rail where it met up with the storage compartment under my back seat. On the rear vertical wall of the storage compartment I drilled a hole and ran the wire loomed bundle through that hole. I used grommets on the hole in the metal and actually doubled up that section of wire loom for added security.
that hole I drilled was next to the rear seat bracket, and then ran the wire loom to the rear wall behind the seat. It’s all protected and out of the way. Safe and secure.
Reactions: alexjusti
billyfromhill
143
Western New York
Another option is the headliner. Pull off the door weatherstripping and you should be able to pull down the edge of the headliner. Many times there is a large amount of room there on the edge of the headliner where it meets the gasket without having to remove anything else. I just did work on a older (2011) Tahoe where we ran a 3/4" bundle of coax and an ethernet cable up the A pillar, over the doors, and down the C pillar to the floor into the electronics area and all we had to pull off was the gaskets and the A pillar trim.
Sparky_911
Supporting Donor
May 15, 2013
2,658
Central Illinois
If you go the headliner route be careful of the side curtain airbags along the top rail of the door frame.
With that much of a bundle you might look at pulling carpet and running it down the tranny tunnel, or split the bundle and run down both door sill plates.
CHUCK4850
