So, I'm looking at using a Liberty WECAN IO board as a pseudo flasher. Being able to essentially control each lighthead seems like a good idea.
I do have a few questions. I see some older WECAN boards are 'dumb' boards and can't be programmed on the fly. When is the cutoff? How do I identify which boards are fully programmable and which ones are limited?
How many amps is each output on an IO board?
Is it negative switched or positive switched?
What is the response time of activating an input and lighting a corresponding output?
Is there a reason I wouldn't want to go with a newer IO board, like from a Justice?
Is there a different controller from a different lightbar I should be looking at for flexibility, cost, or any other reason?
