solidamber
My new lightbar is half red half blue with red on the drivers side, would normally the mirror beams and grill lights, be the same or opposite?
I oppose this form of lighting, you need splits of colors to be most effective when rolling down the road, moving a color filter or LED light is the best thing to do so the same colors may flash but should be giving you a wider stance.
Say you are half blue and half red, you need to look like this in some fashion or another
Brbtdtdrbr
Or
Brtdbrtdbr
In frontal view so your bar looks as wide as the car giving you a larger footprint to eyes ahead of you
That's a good idea, it's a whelen liberty, so I can easily swap around the modules.I vote for red and blue (spread out) on both sides (provided that you’re allowed to do so). Red is more visible than blue under certain circumstances, and blue is more visible than red under other circumstances, so I’m personally not a fan of having all red on 1 side and all blue on the other side.
However, I do believe in syncing colors when possible (is all blue flashing than all red flashing)
Well if you want to mix it up then do so, the bar I have was 4 corners Amber I'm going to have Wilson change 2 corners to green, I'm going to adjust the inners and see what goes best color wise, otherwise it is one color at a time flashing, each set to a different pattern.But still only have one color flashing at any one time per level?
I wish that they would change the degrees of the lenses or lights, cause when you look at them( due to wavelength I'm told ) the blue is always pointing lower then the red or any other color. They could easily change the degrees of the lense to reflect a more central ( straight left to right ) view of the lights to give a better visibility and lower reflection issue.
