wmzuzuski
First issue is the outputs don't correspond to the diagram -
Example, Output #1 is not Output #1 in the programming. It's actually #4 in my case
http://www.whelen.com/install/14B/14B05.pdf
Also, I can only get the controller to work when something is plugged into the USB port and powered up. i.e. when programming from the PC. I put the USB plug into a usb power and the controller works fine. Unplug it and the controller is off.
I have not connected any of the J8 leads... Is there one of these that will provide me power?
What am I missing
What am I missing
