Rotator filters for JetSonic?
empire5150
1,926
NH
JetSonics had colored rotator filters available for the rotators? News to me. I just bought a jetsonic (chain driven synchronized rotators) It has a center independent rotator and it has a filter on it. Clear center dome of course. Was just wondering how common it was to see this on the Jet series?
denko3
866
SLOVENIA,EUROPE
Never heard jets had rotator filters and i am pretty sure they were not an options.
The jet independend rotators and gear rotators never had L-brackets holder on gears to screw the filter on them.
cmb56
746
Norrköping, Sweden
I have never seen or heard of any filter for the rotators. There are non such information in the service manual and it is completely unnecessary with filters for the rotators due to the JetSonics clear lens with individual colored filter sections.
By the way; if your bar have a center lens section instead of a speaker, you have a JetStream and not a JetSonic.
Sonic = sound. With no sound capability you need another name and in this case it got the name Stream at the end due to the low air resistance.
Michael
empire5150
1,926
NH
I just bought it brand new (NOS) from a retired FS dealer. Maybe a prototype?
tsquale
Oct 12, 2010
10,537
Minnesota, USA
I have a hard time believing it is original. I feel like it would not have the large gaps between the filter and mirror on each end if it was made for it. Lot of dirt and grime around the name plate for being NOS. Was it stored in a barn out of box?!
Reactions: denko3
denko3
866
SLOVENIA,EUROPE
Old style jet first generation.it have 537 signal stat flasher heavy duty,old fuse terminal barrel fuses.
the rotators looks like code3 lp6000 old style because code3 had reflector and filter alu.holders like Z-design profil and not squeer U-desigh profil and nets on reflectors which holds reflectors are same like ok lp rotators.
I would not be suprised in mine apinion if it was made prototip or even custom the amber filter is made very very good if i see right like streethawk rot.filter even almost the same.
Will see when you get it.....
ryan
2,996
Massillon, Ohio
The bars that are listed are all used. Some less then others. The center rotator filter was made by the dealer in house. The domes have a black vinyl decal applied to the dome tops. I just got done picking the shop. The bars he has left are all used that remain.
Reactions: Tony P
empire5150
1,926
NH
Ok. So the chain driven rotators were offered under the Jetstream name? Or is this a Jetsonic and someone removed the speaker and swapped it out for a center dome?
ryan
2,996
Massillon, Ohio
He removed the nuns hat. He had plenty of parts to flop them to the jetstream platform.
Reactions: Tony P
dcb
Lexington, Fayette Co, KY
The nametags varied - Federal labels some at JetSonics, and some as JetStreams. Officially, the JetStream is the all-light model.
And, FWIW - the JetStream might be the most aerodynamic bar ever made... it was tested to have something like 99.6% the same efficiency as no lightbar.
empire5150
1,926
NH
Id like to make it original again. Does anyone have a speaker cover for this available for sale? Also, Did they offer solid color domes for this bar? All the literature I have read just mentions clear domes with colored inserts. I know there are solid color domes in the jet series but I mean for this particular model (model year) JetSonic series.
348
1,017
Idaho
I have a Jetsonic speaker cover I would sell. It has no speaker and is missing the back cover plate but does have a NOS base plate and wires for attaching to a speaker. Overall it's in good shape. PM me if you would like some pictures.
ErikH
