The wrecker bar pictured above appears to have independent rotators so I would dispute FedSigs' assertion that it produces a true synchronized pattern; with the cascade mirrors individually- yes, combined- no.
I think there were as many as 25 patterns
You have seen wrong. There are reflector rotators on both sides. They must be positioned that way to give the alternating pattern 1-3-2-4 instead of 1&4-2&3.I see in the bottom left of this add a model that appears to have both a sealed beam rotator on one side and two halogen rotators on the other side. I've never seen one of those before. Are those pretty rare?
Those are definitely sealed beam rotators ala let model 14 par36 frames although the slow shutter speed blurs the pass. side, the driver's side is a bit easier to identify through the clear lens. The sync chains would be shorter but still the TwinSonic/Aero TwinSonic mechanism.The wrecker bar pictured above appears to have independent rotators so I would dispute FedSigs' assertion that it produces a true synchronized pattern; with the cascade mirrors individually- yes, combined- no.
