Sealing Lightbar Holes
TLE911 LLC.
58
Nebraska
What has everyone found that works best for them for filling hole where lightbar harness goes? As in what type of sealant? silicone or what? I've used a couple of different things but looking for something better. Would like something that comes in white, clear and black colors. AND GO!!!!
hole plugs
7d9_z28
3,048
West Michigan
3M Strip caulk, though i think its only available in black.
Reactions: Jamey@NNE
7d9_z28
3,048
West Michigan
I cannot tell if the OP is asking about sealing around the cables (thats how I interpret it) or if they want to seal a hole where a cable used to be (which is how others seem to be interpreting it)
OP, perhaps you could clear up what it is you are trying to accomplish?
TLE911 LLC.
58
Nebraska
I am speaking of sealing around the cables. I use a silicone base right now. But seems at some point there always ends up being a little wind noise that enters through the hole/seal. Was seeing what other options were out there.
7d9_z28
3,048
West Michigan
Sparky_911
Supporting Donor
May 15, 2013
2,648
Central Illinois
I've seen the local guys use dum dum. It's basically gas tank hole sealer (think silly putty). Its tan/goldish color in a tube. Stays flexible and seals tight. Same principle as the 3M strip caulk I think. Easy to remove even after time and weather exposure.
7d9_z28
3,048
West Michigan
Funny, some guys at work call the 3m Strip Caulk 'Dum Dum'
Hilux01
