That flasher has the ground wire, just like the newer version of the Federal Signal FA-3. The ground wire allows the flasher to flash even when there is no load on one or both output terminals.
Jazz, PM me if you need a flasher like that. I have a ton of the newer Fed. Sig. FA3
flashers with ground. Like @shues said, they will flash LED heads.
