LED Headlights from J.W. Speaker
SIRENNET.COM - Headlights
I know it's not a Warning Light inherently... but with a wig-wag on the high beam it does garner some attention. We are a Master Distributor for J.W. Speaker, so if you are interested in any of their other products, please feel free to ask!
J.W. Speaker Model 8800 LED headlights drop into existing 4" x 6" sealed beam applications without involving complicated retrofit wiring or bracketing. Approved for on-road use in North America and Europe, these headlights are perfect for a wide variety of applications. Outputs are 750 for the Low Beam model and 850 Effective Lumens for the High Beam and Multi-voltage (12-24V) construction provides versatility. Optional side-by-side mounting assembly available.
Features & Benefits:
Available in a 12-24V DC configuration
UV-resistant polycarbonate lens
Rugged solid state LEDs can withstand shock & vibration
Long-lasting LEDs mean never having to replace another bulb again!
Die-cast aluminum housing provides maximum protection
Low profile mount
Plug & play replacements for 1A1 and 2A1 sealed beams in most applications
Optional dual mounting assembly is available in RH or LH configurations
General Specifications:
Lens Material: Hardcoated Polycarbonate
Housing Material: Die-Cast Aluminum
Mounting: Retrofits 1A1 and 2A1 (4" x 6") sealed beams
Connector: AMP (#172615-2)
Mating Connector: LH Terminal - AMP (#172795-1); RH Terminal - AMP (#172796-1)
Technical Specifications:
12-24V DC Input
10.5-32V DC Operating Voltage
3.60 Amps @ 12V DC
1.50 Amps @ 24V DC
Effective Lumen Output: 750 and 850
Standards Compliance:
DOT-Compliant FMVSS 108
CMVSS 108 Buy America Compliant
ECE Reg. 112 Sealed to IP67
J.W. Speaker Corporation Lifetime Limited Warranty
Low profile mount
12-24V DC Input
3.60 Amps @ 12V DC
1.50 Amps @ 24V DC
