I have a used but in good condition Axixtech SV56 Stealth Visor undercover interior light bar with universal mounting brackets. R/W/A/R-TD-TD-R/A/W/R
It comes equipped with 56 LEDs. (1 Watt, Gen. 3) These interior led undercover light bars utilize the popular XM series modules, and even use (2) 4S series light heads as take downs, cutting down on heat, and increasing efficiency and brightness
Dimensions: Each housing is 17-1/8" long, 1-3/8" tall. The depth of the flash shield is 4-1/8 at the outer ends & 6-1/8" at the inner ends. The connecting cable between the housings is 11.9" long. Power cable comes with a quick disconnect you add your power and ground.
Asking $250 shipped.
