I want to wire in my sho-me negative switched controller with my sound off signal trafficmaster but I don't know if they're compatable. If anybody has a wiring diagram please let me know. Thanks, Mike.
Is this your TA? I believe it's negatived switched, but not sure. If so, it's relatively.... just match up the correct TA module wire to the correct controller output.
You do know negative switched means you hook up the negative wires of the traffic advisor to the negative outputs (switched) of the controller, and the positive goes to the main one on the controller.
negative to each respective negative lighthead, positive to positive.
Ok I hooked up the sos controller and got my volt meter out. comparing the current that was comming out of the pins in the back of it with the color coded wires from the bar the colors didn't match with the wiring diagram that I had. Somebody switched a few wires around inside the bar. Red wasn't + it was used for a ground wire for a led mod. The black wire was the + for the bar. So yes the SOS trafficmaster is neg switched but it helps if somebody doesn't cob it up on you.
