Soundoff headlight flasher
texaschad25
11
Grandview, Texas USA
I'm trying to wire in a Sound off headlight flasher on a 96 F350, and I'm needing help. Used flasher, no directions, wired it in the same way as another SO flasher, but this one just illuminates both high beams...no alternating flash
Model #etrr00bk
Here's how I have it wired..
Red: toggle switch
White: Permanent positive
Green: ground
Yellow: pass side highbeam
Blue: Other side of cut wire that originally fed passenger highbeam
Black: nothing
Any ideas??
Maybe just a worn out flasher..
Black is ground.... ground it
Reactions: Tony P
That may be the high beam over ride
Do you have a model number?
You my also have the trigger wire and +12v crossed as well but won't know until we get a model number
Tony P
Moderator
Sep 13, 2015
1,944
Midwest, USA
Model #etrr00bk is listed in the original post...
iddnt see that on mobile
im looking at various models of S O S flashers, i dont see the model listed... might contact them directly but heres what "most" of them show...
Blue driver side
yellow passenger side
white is to +12v fused constant (battery)
red is activation switch
green is ground
black goes to parking light wire
BLACK WIRE (OPTIONAL Connection): If an “Automatic Nighttime Flasher disable” is required (check with state and municipal regulations) simply ‘T’ or tap this wire into the parking / marker light wire. This feature will disable the flasher whenever the parking / marker lights are turned on
ErikH
