Soundoff Signal Gen3 LED Visor light (updated)
Jeremy0966
248
Idaho
Manufacturer: Soundoff Signal
Item: Gen3 LED Visor Light
Part #: ELV3BVS+R
Price: $185-$199 (Depending on site)
Style: 16 TIR LED GEN3 Visor light
Warranty: Standard 5 year
Dimensions: 11"L x 2.58"W x 3/4"D
Purchased through: eBay for $50+shipping (used)
Link: SIRENNET.COM - SoundOff Gen3 LED Visor Light
Mfg Specs:
All new Generation 3 LED Visor Light is smaller and more powerful to provide undercover lighting that is sure to be seen.
The Gen3 LED Visor Light is easy to install - just plug into a 12 Vdc outlet and securely strap to the visor with adjustable VelcroTM straps. Light may be hard wired for undercover vehicles to discreetly hide wires when needed.
Non-volatile memory recalls last flash pattern used at power up.
Features 16 built-in flash patterns and 5 color combinations
Ideal for undercover detectives, law enforcement professionals and security staff for undercover or supplemental windshield lighting.
Built-in protection from reverse polarity and voltage spikes.
Current Draw: 0.75 amps @ 12.8 Vdc and 0.35 amps @ 25.6 Vdc.
10 - 30 Vdc for world wide use.
5 Year Warranty.
First impressions of the light were its very well built and sturdy. It was a little heavier than i anticipated, more then likely because of the metal heat sink on the back of the light. The light itself is very thin and easy to hide because of its small size. The straps for the light are very large and should fit any visor very easily and secure well. I also like the cord that Soundoff used because its very small in diameter and very easy to manipulate. I was able to hide the wire very easily in the door jam because of its small size and length (12 ft). One thing i noticed is the on/off switch is located on the light itself other then the cigar plug making it a little more difficult to turn on but not a big deal. If you intend on hard wiring the light it obviously won't be an issue. The light is very bright and punches through the factory tint very easily. The TIR optics provide a very good straight on punch but starts to diminish some on angles. But overall for a TIR light the side visibility isn't bad at all. This light is going to be used in the only manner this light can be used, on the passenger visor as a primary warning light. This is really the only way this light can be used unless its used in the rear window.
Performance: 9
Appearance:8
Usefulness: 9
Innovation: 8
Durability: 8
Price 3
Average: 7.5
Conclusion: A very well made, bright, and useful light with a hefty price
Size comparison between Soundoff and knock of Whelen Flatlighter (Same size as original Whelen Flatlighter)
Interior/exterior day vid
Straight on day vid (VOLUME WARNING HIGH WIND)
Night interior vid (flash back demonstration) And i meant to say passenger side dash :duh:
Night exterior
ErikH
