Ss2000 siren, Whelen inner edge
ECM242
Lurking Newbie
Hi,
I have a federal cuda T/A with a smart siren and would like to switch out the cuda with an 8 head inner edge.
Inner edge has a left trigger, right trigger and both together are center out. It also has a warning light trigger.
Is this doable?
I’m figured it best to ask experienced guys before I start hacking thing up for nothing.
Thanks
MtnMan
Senior Member
It’s possible, but you won’t actually use the TA controller in the Smart Siren. Just use two of the Smart Siren auxiliary outputs to run the Inner Edge.
OP
OP
E
ECM242
Lurking Newbie
Thanks for the reply.
Does something like this seem possible?....
They are both 8 head and neg switched ...
Would it work if I unplugged the inner edge flasher and spiced the federal 8 wire cord directly to the head, of course in the correct order....
Members online
Latest Listings
Top Bottom
