For Sale Strobe Style Led Flasher Controller
Miami FL
ChangchungLeds submitted a new listing:
Strobe Style Led Flasher Controller - Strobe Led Flasher Controller Module
The list is for ONE Strobe Leds Flasher ChangchungLeds. How to connect.
Watching the top of the module flasher with the screws to the left, connections are, to the bottom to top. Check the image
1º Connect to Positive 12 volts, use a switch and 10 amperes fuse in this line. No inclued.
2º Connect to Ground
3º Positive Output Channel 1
4º Negative Output Channel 1
5º Positive Output Channel 2
6º Negative Output Channel 2
The Momentary Push Botton Switch is to change the patterns. (No covered...
Read more about this listing...
