Strobesnmore
The E66 switch is a custom make plug and play switch designed specifically for our E66 series of warning sticks. These sticks give you warning and traffic arrow patterns all in one. What makes this switch so nice is that is also gives you and output to run other warning lights off the same switch that activates the E66 warning patterns. So you can switch on the E66 and any other lights you have with one nice pre made switch. The switch will only need to be wired to +12 volts and -12 volts ground then you simply match up the wires from your E66 and you are done. The switch comes with quick splices and heat shrink to cover them up. The switches are all lighted and labeled. The switch also give you the ability to select the flash pattern at your finger tips. Overall a very nice switch which was designed from user/customer feedback. If you have any questions watch the video on the site or email me with any questions. Louis@strobesnmore.com
Strobes N' More
Strobes N' More
