So right now, I have a 10-segment arrowstik on the rear and an MX7000 on the front of the roof. I have halogen flashers on the front bumper. I can go two ways on the sides, and this is where I need votes.
Option 1 would be four Weldon 7" round incandescent flashers. I have 3 red and 1 blue. One would go in each corner, behind the front doors, with the blue on the passenger rear. Flash pattern would be diagonal wig-wag (if viewed from top).
Option 2 would be four whelen pedestal strobes. They are dual heads with split red/blue filters. They would be mounted in the same four corners, facing sideways, but bolted to the roof.
The biggest advantage of the first one is the simplicity. It would take one flasher to run all four. Since there are 8 bulbs in the strobe option, and the power supplies i have handle 4 or 6, i have to run 2 power supplies. Advantage of the strobes is that roof mounting would mean the side door could open without moving a light. I'm leaning toward the simple Weldon incandescent option. Those lights with 1196 bulbs can be seen for miles and then I'll have even more strobes to stack on my next project. Which option would you go with?
