This is a new one for me.
The short of it is that a 4 gang miller switch panel is randomly not functioning.
The lengthy version of the issues...
Sometimes the switches work and sometimes they do not.
Switch 1 activates the lightbar,
Switch 2 unable to find anything hooked to it
Switch 3 is upper work lights
Switch 4 is lower work lights
The Whelen Liberty that was on the truck only partially worked when the truck was purchased. I was asked to figure it out and add some lightheads.
I traced most of the wiring to figure out what was what as it has been worked on a lot.
The switches randomly work with no real rhyme or reason. Sometimes tapping on them will make one or 2 work. what really confuses me is when one is working, sometimes activating one of the other 3 works fine and sometimes when activating one or 2 of the other 3 all go dead. Sometimes activating a random 2nd switch will kill it all and sometimes it takes a 3rd. Ran switch 1 and 3 just fine for a bit while the next day after no changes it wouldnt function.
The switches are independent and appear to have a circuit breaker built into each switch. All 4 are fed from a single line direct from a battery to the bus bar on top of the switches. The 3 back lights for each switch have individual feed line direct to the output terminal of each switch. All I/O connections are tight. I am stumpped because one random switch or combination of switches shouldnt randomly effect another. If a switch was bad or the breaker was tripping (what are the chances that is happening to all 4) I could understand that switch shutting off but not the randomness of it all.
I did send an email to Miller asking for the specs of the switch box unit but waiting to hear back.
