Twinsonic Gear Disassembly
mls60442
159
IL
Is there a way to take apart the gear assemblies for a Twinsonic. I would like to clean them of all the grease and gunk, then regrease.
217729217730217731
Jun 18, 2013
3,717
PA
I'd start by un-mounting the motor from the gear cage.
Then take a look at how it's setup.. appears to be held in place via C-clips and the gears are secured via Roll pins.
Use a punch to back out the roll pins and once the C-Clips are removed they should just slide out.
Alternatively, spray some degreaser all over the gearbox, and then use a rag and toothbrush to clear everything out
ErikH
