For Sale Unitrol 80K "projects"
philyumpshus
1,281
Malone, NY
This listing is for three Unitrol 80K siren amps that need some work. Here are the details:
Amp #1- Ground wire has pulled out of main (3 prong) wiring harness. Needs a new pin or could be hard-wired in. Works 100%
Amp #2- Main wiring harness was cut short to box. There is plenty of wire inside the box to connect to. Works 100%
Amp #3- Missing fuse holder. Wail and Yelp worked on separate occasions but I could not get them to work together on the same test cycle.
The picture is not of these specific sirens but is representative of them. I can send detailed pictures of the "problems" if you'd like.
The price is for one of these, your pick, shipped via USPS flat rate. I will combine them if you want to save on shipping. Let me know in a PM which siren you want so that I can post updates.
Sanman
