firefighter_2000
This is all still a work in progress:
Built this panel for my truck. Working on several custom built parts/accessories for it. This is the current project. It will be mounted in the glove box.
The coiled cord will head up to the switchbox and includes power/ground wires as well as wires to trigger each relay.
The power will be sent to each accessory via the terminal block on the top right.
Here it is mounted in the glove box.
Added a circuit breaker in the bottom for my air compressor.
The wires coming in through the bottom through a hole I cut. Everything comes in/goes out thru there.
Main power is supplied to the panel starting here, through a 60 amp relay, then through a heavy duty Eaton Cutler solenoid. It will be triggered from an ignition circuit inside the under hood fuse panel.
For the trigger... Drill a small hole here:
Then put the trigger wire from the solenoid in through there.
Made this custom "pin" to insert into the open ignition hot cavity of F90/91 (rear power outlet). I've got the fuse in the always hot location so the rear power outlet stays hot for a charger. I actually squared off an ATM fuse leg, then soldered it into a solder & shrink connector. It easily plugs right in. Triggers the solenoid perfectly each time.
Custom pin in place. The top of the pic is towards the front of the truck.
This is the plug under the truck where all wires come in. Passenger side under the carpet. All sealed up with silicone. The right side is towards the front of the truck.
