I'm trying to fix the wiring in my Twinsonic Model 12 MEF. I haven't touched it since I got it last year and it needs to be cleaned pretty bad. I'm just trying to get it wired correctly first. There was a Wagner 550 flasher in it. I don't know if the flasher went bad at some point because there is some homemade wiring in there that hooked the passenger side PAR36 lamps to the passenger side rotator lamp wire. Nothing flashed and I could only get everything to steady burn.
I finally got everything wired correctly (I think). This is how it is currently wired:
When I power up the flashers, only the driver's side lamps flash. The passenger lamps do not flash alternately. They do not even illuminate. If I wire the passenger lamps to the post with the driver's lamps then all four flash simultaneously. I can't get anything to flash off of the center post. Is the flasher bad? I'm assuming it is.
Also, what is the difference between 537 flashers from 550 flashers? I believe most of the Twinsonics were equipped with 537 flashers. Is the 550 flasher fine to use?
