JohnMarcson
Good eye. It does look very similar, essentially identical.This post says FedSig acquired them...but the basic format looks like this TargetTech (mfg in '01):
Based on the overall light design (I didn't have a specific a reason/understanding as you ) and the way the underside was soldered in I was expecting to see the Edwards style bulb when I pulled the dome (a very similar no name strobe is where I pulled my Edwards style bulb), but this one had a commander style bulb literally frozen into the socket and required some very careful screwdriver work going around the base many times to free it. Not sure if that was an aftermarket replacement that just had a very long tenure in that socket or if it was designed that way.These all look like they have the trigger transformer built in (PCB, right underneath the octal socket) so I'd expect the bulb should be like the "Edwards" you posted here.
I wouldn't think the "commander style" flashtube is intended here as it has its own trigger transformer built-in to the base -- but maybe I'm wrong.
I'm hoping to get one to tinker with next week -- N.O.S. 36Volt made in '79
It took me a while to test it, but it just hisses. I need to make sure I don't have the wrong bulb in it. It was sold as not working "thought it was just a bulb but it wasn't" which leads me to think they swapped the bulb with the wrong one. I will need to see what I have lying around.FWIW, I got a couple of samples to work with.
I removed the material in the flash-tube to reveal no trigger transformer:
The wire goes right straight from the socket pin up to the the outer wrapping of the tube.
It might not look like the "Edwards" style FTs...and maybe the pin-outs are different...but in neither case is there any trigger transformer.
I tried using Whelen's S406 and Universal FT -- neither worked -- and the PS hissed at me for even trying (suggesting the PS detects over-voltage and briefly disables the inverter).
I don't grok the PS design yet...very different from Whelen and Lectric Lites (of the same era).
Any luck on your end, John?
It could also be that its the right bulb...but its dead/no good. The "hissing" would theorectically be the same.I think the wrong bulb is in mine, it is hissing and doing nothing else. I'm pretty sure it's the wrong bulb.
I guess either way I need to make sure I find the right bulb to keep testing. Between the bulb drawer and other beacons I'm sure I have sonmething.It could also be that its the right bulb...but its dead/no good. The "hissing" would theorectically be the same.
PLUS: the fact that its hissing is a great sign!
That's what I figured, everything seems to be present except the voltage needed to flash. The wrong bulb being installed was kind of a red herring. I'm going to play with that some more tomorrow. I was successful at reforming capacitors on other strobes, I will keep at it and replace it if there is no change.85V isn't going to flash. This could be just a case of needing to reform the cap.
If you measure increasing V on the cap, then keep the process going...you're reforming the cap!
If not, the good news is that 100uf/450VDC caps are still easy to come by.
Seems very little changed in the board design between ~85 and ~90 -- here's one I have:
I also got one from ~80 in need of some repair:
Someone had already tried to repair the burnt PCB traces (black and white wire above) but missed:
- D44H11 power transistor had a chunk blown out of it
- High Voltage diode was no good
- primary cap was shorted
How did your (top-of-this-thread) Warn-a-lite turn out?
Nice! Congrats!I have mine working. It needed a few connections repaired and a bulb. Here is a stand-in bulb.
Yeah I found one for $8, no trigger pinned the same it was an edwards I think. The stupid light had a bad solder joint under the capacitor that was intermitient because of the weight of the capacitor pressing on it. I found it by pulling on stuff until the windup noise quit. Then the bad bulb made testing tougher until I found a non-trigger bulb.Nice! Congrats!
Flashtube is part #210590 - I don't think its terribly special - any tube in an octal socket pinned out to match the socket, and that _does not_ have a built in trigger should work.
With the utmost honesty, it looks like it may be beyond my skill level. I'm doing the equivalent of checking of it's plugged in or has a blown fuse etc. You will likely see it shortly.With the utmost respect, I bid you no luck trying to get the Gen1 going
