WeCan pattern help
#1texan
271
Texas
So I will try to explain this the best I can, I have seen a pattern somewhere (searching hours on the internet I haven't been able to find it) that I want on my liberty. So here is trying to explain what I want...... 4 lightheads, I want a (for lack of a better term) "bounce" from one side to the other, so 1 flashes then 2 on the left side and then 4 and 3 on the right side (lights in numerical order as if looking at the front of the bar - 1234). I know it may be difficult to understand, any help is appreciated.
Thanks
wilsonbr90
1,427
Corning, New York
Ping pong or single flash works good. Set whatever heads you want primary to 0° then set the other heads to 180°
code352
166
Ontario, Canada
I wouldn't call it that either but thats what whelen calls that pattern. It is the same as the pattern shown from 1:03 to 1:10 in this video
got_yogurt
BC, Canada
Thanks
If you want 1-2-4-3 then you should set the following phases to your flash pattern:
1: 0°
2: 90°
3: 270°
4: 180°
factorone33
492
Merriam, KS
This is the Whelen "ModuFlash" pattern. Set each of your heads to the pattern, then use the phase/delay settings to adjust the sequencing of heads (1, 4, 2, 3, etc.)
mgrimmius
