Hi, I'm new to WeCan-programming.
I'll have an older Whelen Liberty 2 WC coming in in a few weeks.
I've messed around in the WeCan-program to some degree, but I have some questions.
How can I program the modules to have cruise in the backround, and flash at higher intensity. So that the modules are never completly off. Or perhaps alternate the two, in for example action flash, one side is at cruise intensity, while the other side is lit up.
Or maybe just the corners, hope you get my idea. And will all this be within the same input (Will be using Control Point), or can I use a second input to turn on/off the "backround" cruise lights while the flashpattern is active.
And I still can't quite figure out what the pattern override will do. What's the difference between pattern override, and making a higher priority on that given input?
