Weird NYPD ESU Truck
Phoenix_Rising
Resident Ghost
Gold Supporter
Diggin it hardcore. NYPD ESU has a good knack for having the right stuff in the right places, without being ridiculous
ff168577
Senior Member
It looks like this was a post 9-11 truck as it is a 2002. It used to be MALT (Mobile Auxilliary Light Truck) 4, and ESU 4 was a 2002 Mack. I assume the original 4 truck was due to be replaced and MALT 4 got moved over to 4 truck because it might not have been used as much. I'm just speculating. But I absolutely love the lighting. Especially the front grill.
CHIEFOPS
Senior Member
It's not 'Truck 4', Truck 4 is a ginormous model year 2014 or 15 Saulsbury heavy duty walk-in rescue truck RMP number 5704, this is a smaller support vehicle that's assigned to Squad 4 whose designated role isn't specified with any markings.
pdk9
Veteran Member
Love the truck. I'm wondering if it's a remounted chassis....it looked like an older saulsbury body (with original LED and steobe lighting on the sides) mounted a newer international chassis. Saulsbury has been out of business for a while (E-One bought them out a while ago) but that international chassis definitely doesn't look more than several years old.
I also dig the single FedSig halogen pods there, combined with strobes for intersection. I like that much better than the 3 smaller FedSig intersection lightheads on the newer E-One custom chassis trucks
dg0223
It would look good if all of the halogen rotating stuff was replaced with the Vision SLR and single SLR pods where the rotators are on the bumper. I don't even know if they make single pod SLR stuff, but it would look good.
CrownVic97
Veteran Member
Federal Signal does make single pods or beacons with SLR tech! Check it out ;-)
OP
OP
C
classifieds869294
Established Member
I wish I could give you a better answer, but googling did not yield much. I vaguely recall reading something that said something was modified to cause both the wail and yelp to be "flipped" vs. the contemporary (at the time) standard black face PA300's, making it sound reminiscent of the silver face models. You can hear a very subtle difference between the FDNY yelp and silver face yelp.
Also, the FDNY spec siren did not have hi lo. The label is there but there's no hi lo.
cw702
Registered Member
The msb has a peak and hold to the manual tone vs the msc and NY which has wind down manual tones
shues
Lifetime VIP Supporter
I was under the impression that the MSB indicated a 200-watt PA300, and that the MSC indicated a 100-watt PA300.
There's been a lot of discussion about the NYPD spec PA300 on this thread: https://elightbars.org/forums/threads/old-nypd-electronic-sirens.27373/
Information about these things is pretty sparse, this very well might be PA300 that the NYPD was said to use in 1990, after the Mark VII and before the Smart Siren came on the 1991 Caprices. Apparently that model had peak and hold manual.
I happened to just pick one of these up and also reached out to FS for an install manual on it. Attached is the addendum for these specific units. It seems there are some changes to the horn ring circuitry which I haven't tested yet. The horn/manual switch works a bit different. The manual is peak and hold versus wind down. The horn emits a very strange almost "tone" like sound instead of a horn sound. Not sure if that is an issue with the siren I picked up or they are all like this. I searched the web and see Port Authority specd the same sirens for a vehicle bid they did back in 2015.
OP
OP
C
classifieds869294
Established Member
Ha that’s very interesting. So it looks like you can also set it up for yelp when you press the horn in the manual position. Would love to see/hear a clip of your unit if it’s feasible.
Port Authority has some unusual vehicles, including airport and tunnel fire trucks This one comes to mind and could very well be a PA300
FCV96
Junior Member
I’m not familiar with the MSB, what was that used for? I wish I could find a good clip of the NYPD model, I have no idea what those sounded like.
I think that this is a clip demonstrating the manual yelp from the NYPD PA300's. Start at 1:09 for an awesome shot of a Caprice RMP leaving the 73PCT parking lot, and the actual manual tone starts at around 1:24. It looks like the driver is using the horn ring to activate the tone. You'll have to turn your speakers up - the audio on the clip is fairly low.
CHIEFOPS
Senior Member
IIRC our (NYPD) PA300s did not have manual Yelp, they were instant peak and hold with no coast down, both the horn ring and the paddle switch.
In the video I think the Recorder (passenger officer) has the siren in yelp and using the PA override to manually activate it.
FCV96
Junior Member
No, I think the Recorder (passenger officer) has the siren in yelp and using the PA override to manually activate it
Ah, that could be it too. The driver seems to have his left thumb on that horn quite often when it's in view, but maybe that was a comfier driving position.
CHIEFOPS
Senior Member
Habit from routine operation.
The Recorder was PO Mike Sutch, there were 2 Sutch brothers, one of them was in my Academy company, it's been so long I forget which but I think it was Mike.
OP
OP
C
classifieds869294
Established Member
Wow, finally some footage appears. Thanks! I think in the last response in that video, you might hear one blip of the peak and hold but I'm not sure.
View My Video
Attached is a quick video showing all the tones on the NYPD PA300 I have. I have to wonder if the air horn sound is correct or if there is an issue with the siren. All the other tones seem appropriate. I have horn ring on a momentary button on my PCC8R instead of tying into the actual car horn.
When in manual mode siren on the paddle switch is a wail peak and hold tone. The horn ring does a momentary yelp peak and hold. The horn tone on the siren almost sounds like a peak and hold hi-lo pitch.
CHIEFOPS
Senior Member
View My Video
Your incessant tone switching prevents anyone from assessing the siren.
Online statistics
Members online
13
Guests online
99
Total visitors
112
Forum statistics
Mannaro
Top Bottom
