Whelen 295SLSA6 controller
Jtsou
281
NC
hi,
My patrol vehicle is equipped with a Whelen 295SLsA6 controller, manual is here:
when I stop a car the slide switch goes all the way to the right (level3) to activate my warning equipment and in car camera. I stop most cars out on the highway so I often use my traffic advisor in addition by pressing one of the 6 output buttons, this overrides the center lights on my rear inner edge.
My problem is I remember to turn my slide switch off but never the traffic advisor so on a couple occasions I go cruising down the road with my TA on ‍♂️
Can this controller be programmed to cut the outputs to the 6 momentary switches at the same time I cut the slide switch off?
Thanks.
Bvfa23
147
Depew, New York
I don't think you can achieve what your after with that siren, you would need something programmed by a computer like the Cencom to turn off the outputs when the slideswitch is turned off.
I did have a switch come ON AND off with the slide when I had the same unit but that wouldnt work for all 3 directions
ErikH
