Whelen 400s, Freedom corners, **FOUND ALL 12-13-14**
Sparky_911
Supporting Donor
May 15, 2013
2,656
Central Illinois
Upfitting an EDGE bar and seeking following parts
WHELEN 400'S...will take any colors as long as the housings are intact and have amp/molex connectors or decent pigtails.  Prefer BLUE/BLUE, BLUE/WHITE WHITE/WHITE   Linear or not fine. Discolored/burnt out LEDs fine, so long as the boards power on.  I need 8 heads total...must be dual row 6/6 heads like this....
WHELEN FREEDOM...ISO 4 freedom corners.  Dual row LED heads preferred, will take older single row heads. EDIT 11-11-14:  Same as above...prefer BLUE/BLUE, BLUE/WHITE WHITE/WHITE  Linear or not fine. Discolored/burnt out LEDs fine, so long as the boards power on.
Cash or trade...I have  5 BLUE FS Solaris heads, 6 WHITE pop in style HAW strobe tubes, 2 AMBER 2 screw style HAW strobes, 2-16ft lengths of whelen strobe cable with ends, some ETD BLUE lights...(Chinese) bumper LEDs, 4 head tir dash light, pair of exterior tir heads needing ballast/flasher, FS Firebeam BLUE with addt'l half blackout cover.
Will have available soon...4 Edge linear corner strobes w/halogen TD's, and 6 head power supply(EB6), FS Smart Vector w/SNM (see my vids)  with a banana box of parts (local p/u only),
FOUND   Also looking for 2 pin and 3 pin amp connectors.  M/F plastics and pins.  Looking for bulk (20 or more)
                       11-15-14 found 2 400 heads.
mojo3120
84
Charlotte, NC
You can easily buy the amp connectors in bulk from an electronics supply house like mouser or digikey
Pretty sure these are the AMP part #'s for the 3 pin
1-480305-0
1-480303-0
pins
60619-4
60620-4
Sparky_911
Supporting Donor
May 15, 2013
2,656
Central Illinois
Thanks. I have been looking at new, but was hoping to come across someone here that upfits bars and may have a bunch of used plastics or overstock of new pins they might want to make a buck on.
Sparky_911
Supporting Donor
May 15, 2013
2,656
Central Illinois
Updated...Found amp connectors...still searching for the rest...
Sparky_911
Supporting Donor
May 15, 2013
2,656
Central Illinois
Updated...down to needing 8 400 heads....taking any colors and still prefer anything with half or whole head BLUE.
Sparky_911
Supporting Donor
May 15, 2013
2,656
Central Illinois
3 leads on BLUE Freedom corners.  Awaiting PM responses.
Sparky_911
Supporting Donor
May 15, 2013
2,656
Central Illinois
Found a full on Freedom for a steal...no longer searching for parts.  Will close this thread after the Freedom deal goes thru.
Sparky_911
Supporting Donor
May 15, 2013
2,656
Central Illinois
Parts found.  Thread can be closed
bassslogic
