Whelen 9M
jdh
Geneva, FL
I have the version with the strobe arrow stick, does someone have the distribution board diagram. I can't find it on whelen's web site.
Please PM me if at all possible.
Thanks
emtanderson51
3,795
USA Massachusetts
I believe an external supply runs it...If you can't locate the diagram you just set the pattern to left on the supply, add power, then plug and unplug to get them into sequence. Once that's done the rest of the patterns should be all set.
jdh
Geneva, FL
I was looking for the 9M control board pin outs. It was similar to the relay matrix board. The 9M has the strobe arrowstick power supply in the bar. It is set up the same as the Tomar bars.
KeystoneDiesel
