Whelen Cencom Gold Flasher Capabilities
Yet another random Whelen related question from me:
So I figured out the esiest way to make a TA is with a 12 pin connector, so a controller with a 12 pin port would be needed. I figured maybe an ol' Cencom Gold would work as they've got 12 pin TA ports. However, before I eventually buy anything, does the Cencom Gold have any internal flasher that could flash 4 pairs of (BAsic 2 wire power/ground) 500 series heads (8 total 500 Series heads) and 4 vertexes? Being able to control the TA and the 8 500 Series perimeter light through one control system beats buying a used TA controller, A ULF8, and something to control the ULF8 with (Some switchbox). I was looking at the Whelen Cencom Gold PDF (Refer to Pg. 5&9) and listed the following outlets: (1) 40 amp, (2) 20 amp, (5) 10 amp and (4) 0.25 amp. On the diagram on Pg. 9 it shows the location of the 40 and 20 amp outputs, but it doesn't identify the 10 and .25 amp outputs. So yeah if anyone know if the Cencom Gold has internal flashers capable of flashing 8 500 Series heads and 4 vertexes, do let me know!
Cencom gold does not have any internal flasher. The only Whelen platforms that flash are Carbide, Cantrol, and Core. There is a work-around with Sapphire though. You can get an expansion module(these are listed as not compatible with Sapphire) and program it as an inner edge, and use it to flash outputs. Ive never done this, so this is as specific as I can be, but it has been done and explained on a few FB groups.
Ah, okay. Wasn't sure if the Cencom Gold had any sort of flasher, hence the post. Do you know it something like a ULF8 can be used together with a Cencom Gold? Then that could handle the external flashing while still having certain things flash with each slide switch position all under the same control head.
shawn1
